Bibliothèque DCCpp
Encore un DCC++ ? Mais à quoi ça sert ?
. Par : Thierry
J’ai toujours beaucoup de problèmes dans la mise en oeuvre de DCCpp. Je suis passé à une connexion Ethernet. Mon croquis est le suivant :
project: <Dc/Dcc Controller>
author: <Thierry PARIS>
description: <Dcc Ethernet Controller sample>
#include "DCCpp.h"
#if !defined(USE_TEXTCOMMAND) || !defined(USE_ETHERNET)
#error To be able to compile this sample,the lines #define USE_TEXTCOMMAND and #define USE_ETHERNET must be uncommented in DCCpp.h
// the media access control (ethernet hardware) address for the shield:
uint8_t mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x76, 0xB6 };
//the IP address for the shield:
uint8_t ip[] = { 192, 168, 1, 14 };
EthernetServer DCCPP_INTERFACE(2560); // Create and instance of an EthernetServer
pinMode(53, OUTPUT);
digitalWrite(53, HIGH);
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
Serial.begin(9600);
DCCpp::begin();
// Configuration for my LMD18200. See the page 'Configuration lines' in the documentation for other samples.
// DCCpp::beginMain(UNDEFINED_PIN, DCC_SIGNAL_PIN_MAIN, 3, A0);
DCCpp::beginEthernet(mac, ip, EthernetProtocol::TCP);
Serial.print("DCCpp démarre et Internet est supposé lancé");
Serial.println();
DCCpp::loop();
Je reçois le message suivant à la compilation :
Arduino : 1.8.13 Hourly Build 2020/02/14 03:33 (Windows 10), Carte : "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:30:6: error: 'Output' has not been declared
void Output::begin(int id, int pin, int iFlag) {
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void begin(int, int, int)':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:37:6: error: 'firstOutput' was not declared in this scope
if (firstOutput == NULL) {
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:38:17: error: invalid use of 'this' in non-member function
firstOutput = this;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:40:12: error: 'get' was not declared in this scope
else if ((get(id)) == NULL) {
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:40:12: note: suggested alternative: 'gets'
gets
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:3: error: 'Output' was not declared in this scope
Output *tt = firstOutput;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:3: note: suggested alternative: 'Outputs_h'
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:11: error: 'tt' was not declared in this scope
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:44:20: error: invalid use of 'this' in non-member function
tt->nextOutput = this;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:48:2: error: invalid use of 'this' in non-member function
this->set(id, pin, iFlag);
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope:
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:60:6: error: 'Output' has not been declared
void Output::set(int id, int pin, int iFlag) {
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void set(int, int, int)':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:61:2: error: invalid use of 'this' in non-member function
this->data.id = id;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:62:2: error: invalid use of 'this' in non-member function
this->data.pin = pin;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:63:2: error: invalid use of 'this' in non-member function
this->data.iFlag = iFlag;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:64:2: error: invalid use of 'this' in non-member function
this->data.oStatus = 0;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:2: error: invalid use of 'this' in non-member function
this->data.oStatus = bitRead(this->data.iFlag, 1) ? bitRead(this->data.iFlag, 2) : 0;
In file included from C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:9:0:
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:31: error: invalid use of 'this' in non-member function
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:111:32: note: in definition of macro 'bitRead'
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:62: error: invalid use of 'this' in non-member function
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:15: error: invalid use of 'this' in non-member function
digitalWrite(this->data.pin, this->data.oStatus ^ bitRead(this->data.iFlag, 0));
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:31: error: invalid use of 'this' in non-member function
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:60: error: invalid use of 'this' in non-member function
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:75:10: error: invalid use of 'this' in non-member function
pinMode(this->data.pin, OUTPUT);
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:80:6: error: 'Output' has not been declared
void Output::activate(int s){
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void activate(int)':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:81:3: error: 'data' was not declared in this scope
data.oStatus=(s>0); // if s>0, set status to active, else inactive
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:81:3: note: suggested alternative: 'atan'
atan
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:107:1: error: 'Output' does not name a type; did you mean 'Outputs_h'?
Output* Output::get(int n){
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:114:6: error: 'Output' has not been declared
void Output::remove(int n){
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void remove(int)':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:3: error: 'Output' was not declared in this scope
Output *tt,*pp;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:3: note: suggested alternative: 'Outputs_h'
Output *tt,*pp;
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:11: error: 'tt' was not declared in this scope
Output *tt,*pp;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:15: error: 'pp' was not declared in this scope
Output *tt,*pp;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:117:10: error: 'firstOutput' was not declared in this scope
for(tt=firstOutput, pp = NULL;tt!=NULL && tt->data.id!=n;pp=tt,tt=tt->nextOutput);
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:129:10: error: 'firstOutput' was not declared in this scope
if(tt==firstOutput)
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:146:5: error: 'Output' has not been declared
int Output::count() {
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'int count()':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:2: error: 'Output' was not declared in this scope
Output *tt;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:2: note: suggested alternative: 'Outputs_h'
Output *tt;
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:10: error: 'tt' was not declared in this scope
Output *tt;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:149:12: error: 'firstOutput' was not declared in this scope
for (tt = firstOutput; tt != NULL; tt = tt->nextOutput)
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:220:6: error: 'Output' has not been declared
void Output::parse(char *c){
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void parse(char*)':
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:3: error: 'Output' was not declared in this scope
Output *t;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:3: note: suggested alternative: 'Outputs_h'
Output *t;
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:11: error: 't' was not declared in this scope
Output *t;
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:227:9: error: 'get' was not declared in this scope
t=get(n);
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:227:9: note: suggested alternative: 'set'
t=get(n);
set
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:240:7: error: 'create' was not declared in this scope
create(n,s,m);
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:240:7: note: suggested alternative: 'rename'
create(n,s,m);
rename
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:257:1: error: 'Output' does not name a type; did you mean 'Outputs_h'?
Output *Output::create(int id, int pin, int iFlag){
Outputs_h
C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:312:1: error: 'Output' does not name a type; did you mean 'Outputs_h'?
Output *Output::firstOutput=NULL;
Outputs_h
exit status 1
Erreur de compilation pour la carte Arduino Mega or Mega 2560
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
J’ai sorti "les résultats détaillés de la compilation", mais cela 39 KO de texte ! Je peux les rendre disponibles si nécessaire.
Ma sélection DCCpp.h est la suivante :
// Inclusion area
#define USE_TURNOUT
//#define USE_EEPROM
//#define USE_OUTPUT
#define USE_SENSOR
//#define USE_ETHERNET_WIZNET_5100
#define USE_ETHERNET_WIZNET_5500
//#define USE_ETHERNET_WIZNET_5200
//#define USE_ETHERNET_ENC28J60»
Merci par avance de votre assistance
Claude
98 Messages
Bibliothèque DCCpp 26 décembre 2017 10:25, par bagou91
Merci pour cet article et la présentation de cette bibliothèque.
Après lecture, j’ai l’impression que cela va être bien plus simple à utiliser pour se concevoir un circuit avec quelques accessoires et locos.
Jusqu’à présent j’ai essayé plusieurs bibliothèques proposées : d’un coté les accessoires, d’un autre le contrôle des locos, mais sans vraiment pouvoir tout réunir.
Avec cette bibliothèque, je crois que c’est chose faite :
Les quelques exemples donnés montrent la gestion d’accessoires en même temps que le contrôle des locos.Plus qu’à mettre en pratique :)
Bibliothèque DCCpp 31 décembre 2017 18:35, par BobyAndCo
Ma petite contribution à ce formidable travail. J’ai pu tester la bibliothèque de Thierry en mode TEXTCOMMAND, en Ethernet avec le LMD18200 et aussi le POLOLU MC33926 Motor shield.
Je n’ai rencontré aucun problème, que ce soit en pilotage sur la voie Main ou en programmation, sur la voie Prog avec l’une et l’autre des cartes moteur.
Il ne faut pas oublier de modifier le fichier DCCpp comme cela est indiqué dans l’article (lignes 310 et 312 à décommenter)
/**Comment this line to avoid using and compiling Serial commands.*/ #define USE_TEXTCOMMAND /**Comment this line to avoid using and compiling Ethernet shield using Wiznet 5100 chip (Arduino Shield v1).*/ #define USE_ETHERNET_WIZNET_5100
mais vous serrez rapidement rappelé à l’ordre en cas d’oubli au moment où vous chercherez à téléverser le programme sur l’Arduino.
Pour cela, dans le menu Exemples de l’IDE d’Arduino, on choisit EthernetDCC. Si vous utilisez un LMD18200, vous n’aurez rien à modifier, sauf une petite erreur qui est juste dans l’exemple (pas dans l’article). Sur la voie Main, la broche pour le PWM est la 3 et non la 11 (la 11 étant celle de la voie Prog)
Voici le code modifié et complété :
// Configuration for my LMD18200. See the page 'Configuration lines' in the documentation for other samples. DCCpp::beginMain(UNDEFINED_PIN, DCC_SIGNAL_PIN_MAIN, 3, A0); DCCpp::beginProg(UNDEFINED_PIN, DCC_SIGNAL_PIN_PROG, 11, A1);
En cas d’utilisation d’un Pololu, le code à ajouter est celui-ci :
// Configuration for my POLOLU MC33926 Motor shield. DCCpp::beginMain(POLOLU_DIRECTION_MOTOR_CHANNEL_PIN_A, DCC_SIGNAL_PIN_MAIN, POLOLU_SIGNAL_ENABLE_PIN_MAIN, POLOLU_CURRENT_MONITOR_PIN_MAIN); DCCpp::beginProg(POLOLU_DIRECTION_MOTOR_CHANNEL_PIN_B, DCC_SIGNAL_PIN_PROG, POLOLU_SIGNAL_ENABLE_PIN_PROG, POLOLU_CURRENT_MONITOR_PIN_PROG);
Bravo encore.
Bibliothèque DCCpp 2 janvier 2018 11:13, par DDEFF
Magnifique travail !
Je n’ai malheureusement pas encore de réseau, mais il est évident qu’il sera commandé avec cette bibliothèque.
Pour l’avoir découvert la première fois, j’avais bien saisi le potentiel de l’appli de Greg, qui mêlait le C++ pour l’Arduino et Processing pour l’interface de commande des trains.
L’interface Processing était efficace, mais uniquement adaptée à son réseau, vraiment spécifique. L’adapter à un autre réseau est complexe.
Mais elle permet d’envoyer à l’Arduino des commandes simples qui respectent parfaitement les normes DCC.
Il s’ensuit qu’on peut déconnecter la partie Arduino et la partie Processing. C’est ce qui a déjà été fait dans les très bons articles de Dominique et Christophe qui ajoutent chacun une fonctionnalité.
Tu ajoutes une idée force supplémentaire en créant une bibliothèque qui permet de ne plus se soucier d’avoir à intervenir directement dans le programme.
Un grand bravo ! -
Bibliothèque DCCpp 2 janvier 2018 21:57, par Thierry
Merci pour votre soutien. Il reste des pistes d’amélioration, comme la disponibilité pour un ESP32, un ESP8266 ou un STM32. Et puis l’accès aux commandes via Wifi... Encore du boulot !
Bibliothèque DCCpp installation 5 janvier 2018 00:40, par Rob1
Une petite question de débutant pour enfin m’associer aux remerciements et félicitations.
Les sources à utiliser sont-elles celles que l’on trouve dans
Biblios et Logiciels DCC + BaseStation-master + DCCpp_Uno
J’hésite car il n’y a pas DCCpp.h Si oui doit-on le créer au même niveau que DCCpp_UnoRob1.ino ?
Peut-être ai-je raté un lien dans l’article.Merci d’avance pour votre aide
Bonjour, merci de l’intérêt porté à mon travail. Comme indiqué dans l’article (dans le chapitre "Où ça se passe...", mais je reconnais que ce n’est pas très visible...), la bibliothèque est ici (https://github.com/Locoduino/DCCpp/...) et se suffit à elle même.
Je crois qu’il est temps de mettre à jour les articles sur le DCC en pointant maintenant sur la bibliothèque DCCpp de Thierry qui simplifie considérablement le travail du développeur.
Cela n’enlève rien à l’intérêt de l’article Réalisation de centrales DCC avec le logiciel libre DCC++ qui explique les entrailles de DCC++ qui reste à l’identique dans la bibliothèque de DCCpp.
Merci de cette prompte réponse. Une lecture plus attentive aurai éviter la question mais je suis comme le temps, tous les jours un peu "plus vieux".
Bibliothèque DCCpp 6 février 2018 18:52, par pat95
Bonjour, bravo pour le travail réalisé je m’associe aux félicitations.
Je n’arrive pas à faire fonctionner la nouvelle bibliothèque avec mon ancien dossier DCC_Ethernet de BobyAnco !!
j’ai réussi avec la liaison SERIAl mais rien avec l’exemple ethernet. Est-ce le dossier HTML sur la carte SD qui bloque ? Faut-il reprogrammer un nouveau fichier HTML ? Merci d’avance pour votre aide. -
Bibliothèque DCCpp 6 février 2018 20:40
Bonjour et merci.
Avez vous fait ce qu’il faut dans DCCpp pour gérer une liaison Ethernet, c’est à dire activé USE_TEXTCOMMAND et l’un des shields réseau avec USE_ETHERNET_* ?
Quel fichier ino employez vous ?Le fichier HTML n’y est pour rien, il s’agit beaucoup plus probablement d’une absence de connexion au réseau...
Bibliothèque DCCpp 7 février 2018 13:12, par pat95
j’ai fait fonctionné l’exemple SerialDcc sans problème. Je crois que mon problème est de lire sur la carte SD le fichier "control.htm" fichier en HTML. Comment faire ?. Je cherche...
Bibliothèque DCCpp 7 février 2018 14:07, par pat95
j’ai testé l’exemple serialDcc sans problème. J’ai ensuite chargé l’exemple EthernetDcc, modifié mac[], activé #define USE_TEXTCOMMAND, sélectionné #define USE_ETHERNET_WIZNET_5500 (arduino.org, ethernet2), modifié DCCpp::beginMain(UNDEFINED_PIN, DCC_SIGNAL_PIN_MAIN, 3, A0) ;. Et rien... Rien sur la console pas même la connexion ethernet !!. Je continue à chercher. -
Bibliothèque DCCpp 26 février 2018 17:10, par Didier44
Je découvre seulement tes bibliothèques, occupé par ailleurs par la construction de mon réseau. Un seul mot : bravo. Je viens d’essayer ton exemple Autotest et ton mini "programmateur" me donne bien des idées.
Bibliothèque DCCpp 3 mars 2018 13:27, par Jocelyn DAVID
Bonjour, je viens de télécharger la dernière version DCCpp-1.1.0 et je ne suis pas capable d’afficher le fichier DCCpp.h pour le modifier. Je suis allé voir sur le forum sans trouver l’astuce. Soit je suis (assez ?) nul, soit c’est bien caché. Merci pour votre retour
Bibliothèque DCCpp 3 mars 2018 15:44, par Thierry
Si vous avez installé correctement la bibliothèque comme expliqué dans l’article Installer une bibliothèque , vous avez un répertoire ’Libraries/DCCpp/src’ à côté de vos croquis Arduino (dans ’Mes documents/Arduino’ sous Windows) . Vous y trouverez le fichier en question. Si vous n’avez que téléchargé le fichier zip, il vous faut installer la bibliothèque.
Bibliothèque DCCpp 3 mars 2018 16:58, par Jocelyn DAVID
Merci, Thierry. J’ai effectivement trouvé après coup le fichier dans le sous-répertoire "src". L’aventure continue ... Pas facile de se remettre à niveau après 20 ans d’interruption (sans jeu de mots)... aha
Bibliothèque DCCpp 6 mars 2018 11:17, par Jocelyn DAVID
Bonjour à tous les lecteurs. Ma quête laborieuse se poursuit. J’ai quelques questions complémentaires. J’ai fait l’acquisition de 2 locos "N" Bachmann avec "DCC on board". Jusque là, pas de soucis (sauf si quelqu’un a rencontré des problèmes avec ce matériel ?). Par défaut, l’adresse du décodeur est "3". En faisant fonctionner mon Arduino Uno + LMD18200 + MAX471 avec une seule loco sur la voie principale et avec la bibliothèque CmdrArduino, aucun problème. J’ai donc testé la bibliothèque DCCpp ... puis DCC++ BaseStation, rien ne va plus. Par exemple, le mode TEXTE ne produit aucune réaction. Est-ce que quelqu’un a une idée du problème ? merci pour votre retour.
Bibliothèque DCCpp 6 mars 2018 12:02, par Thierry
Qu’entends-tu par ’mode TEXTE’ ? si c’est l’utilisation de la console pour envoyer des commande, il suffit de l’activer dans DCCpp (maintenant que tu as trouvé le fichier :) ) en retirant la remarque devant #define USE_TEXTCOMMAND.
Bibliothèque DCCpp 7 mars 2018 21:00, par Guillaume45
Tout d’abord un très grand merci pour tout ce travail magnifique que vous nous donner et vraiment bravo !!!
J’ai rencontré un petit problème avec la bibliothèque DCCpp et la dernière version de l’ide arduino.
erreur de compilation #include "arduino.h" manquant.
j’ai réussi à résoudre ce problème en remplaçant "arduino.h" par "Arduino.h" dans le fichier source DCCpp.cpp et Config.h .Je cherche à commander mes trains en utilisant la fonction DCCpp::setSpeedMain(......)
A quoi le paramètre nreg ou registre et comment faire pour piloter plusieurs locomotive simultanément ?
Lorsque l’on ne veut plus commander une loc, existe -t-il une fonction pour faire un raz ?Merci pour votre aide
Guillaume -
Bibliothèque DCCpp 8 mars 2018 09:34, par Thierry.
Bonjour et merci :)
Je vais corriger les includes et pousser une nouvelle version. Le problème vient de mon Windows qui n’est pas sensible à la casse des noms de fichiers. Alors quand c’est compilé sur un MacOs ou un Linux, il peut y avoir des problèmes que je n’ai pas vu...
Comme je l’explique dans la doc livrée avec la bibliothèque (sous Windows lancer startdoc.bat du répertoire de la bibliothèque, sinon lancer le fichier html DCCpp\extras\Doc\index.html dans un navigateur), chaque registre est un canal de commande DCC. Conformément à la norme, les ordres DCC doivent être répétés à l’infini pour qu’une loco qui perd le contact électrique avec la voie pendant une milliseconde retrouve sa consigne dès que le contact est rétabli. Chaque registre contient donc un ordre à répéter. On peut jongler avec les onze registres en répétant onze ordres pour la même loco, ou en pilotant onze locos, ou en mixant les deux...
Et non, il n’y a pas de Raz dans DCCpp, mais des commandes similaires existent dans la norme DCC. -
Bibliothèque DCCpp 2 avril 2018 09:03, par Guillaume45
J’apprends à utiliser votre bibliothèque depuis quelques semaines, et je ne rencontre aucune difficulté pour la commande des locomotives.
Par contre pour la lecture des CV sur voie de prog, c’est un peu plus compliqué.
la fonction "identifyLocoIdProg" me donne bien la bonne valeur.
l’écriture cv prog à bien fonctionné aussi ( j’ai juste reprogrammé l’adresse)
mais la lecture cv "readCvProg" me retourne toujours -1.
y a t’il une particularité pour l’utilisation de cette fonction ?
(pour info j’utilise 2 lmd18200 avec max471)Merci pour votre aide
Guillaume -
Bibliothèque DCCpp 2 avril 2018 10:05, par Thierry
Content de voir que ça marche ! Pour la lecture des CVs, il y a un petite incohérence dans mon code qui fait que la lecture de l’adresse ne peut fonctionner que sur la voie principale, tandis que la lecture de CV peut se faire sur les deux voies...
Si votre décodeur est sur la voie principale, cela peut expliquer le fonctionnement que vous décrivez. L’adresse est bien lue, mais readCvProg ne peut pas fonctionner... Si votre loco avait été sur la voie de programmation, la lecture de l’adresse aurait échoué, mais la lecture des CV aurait réussi !
Je ferais très bientôt une nouvelle version corrigeant ce disfonctionnement...Thierry.
Bibliothèque DCCpp 28 novembre 2018 18:22, par engi
j ai lu plusieurs fois l article, mais quelquechose m echappe.
je ne trouve pas le fichier INO ou PDE.
merci de m eclairer.-
Bibliothèque DCCpp 28 novembre 2018 18:48, par Dominique
C’est normal, c’est une bibliothèque : Une bibliothèque est un ensemble de fonctions qui s’ajoutent aux fonctions de base du logiciel de l’Arduino.
Donc le .ino est dans votre programme, pas dans le bibliothèque.
Lisez donc Installer une bibliothèque -
Bibliothèque DCCpp 29 novembre 2018 09:13, par Thierry
Comme le dit Dominique, c’est une bibliothèque, donc dans les exemples se trouvent des ... exemples, donc des fichiers ino permettant de se servir de DCCpp.
Bonne programmation !
Bibliothèque DCCpp 26 janvier 2019 17:29, par Philippe38
J’utilise la bibio DCCpp avec succès depuis +6 mois. Je la commande à partir d’un GUI/IHM écrit en JavaScript avec node.js. J’ai relu la doc mais je vois pas comment programmer des CV dans les décodeurs d’accessoires en dehors de la voie de programmation. Je souhaiterai programmer en POM comme pour les décodeurs de loco. Il me semble qu’il manque une commande pour y arriver ? Tout ça pour un bit : loco ou accessoire.
Ferroviairement, Philippe38-
Bibliothèque DCCpp 1er février 2019 15:54, par Thierry
Bonjour Philippe,
De quel bit parles tu ? Je ne le retrouve pas dans le document NMRA sur la norme DCC...
Bibliothèque DCCpp 1er février 2019 18:20, par Philippe38
J’explique en détail : je souhaiterai programmer les CV de mes modules accessoires en POM. Mais l’adresse des accessoires (1..2048) est la même que celles des locos (1..10240). La différence d’adressage entre loco et accessoire est gérée en interne par DCCpp avec le début de l’octet 1 de la trame DCC : 0x.. = loco adresse courte, 11.. = loco adresse longue, 10.. = accessoire. Ca tient à un bit qui fait la différence.
Comment programmer un accessoire en POM ? Il manque une commande dans TextCommand.h me semble-t-il. Est que c’est envisageable de rajouter une commande ? "A" est libre par exemple. J’ai regardé le code en profondeur mais cela ne parait pas très simple...
Merci pour la bibliothèque, un sacré boulot.
Bibliothèque DCCpp 2 février 2019 13:35, par Thierry
Je pourrais faire les fonctions en question, mais je ne pourrais pas tester, et en particulier je ne pourrais pas tester la partie remontée d’information via une consommation ponctuelle comme le prévoit le protocole DCC, en tout cas pour les décodeurs de machine...
Bibliothèque DCCpp 2 février 2019 23:53, par Philippe38
Bonsoir Thierry,
mes décodeurs d’accessoires (de Paco et Arduino) ne permettent pas la lecture des CV comme beaucoup d’autres, que ce soit en POM ou en voie de programmation. D’ailleurs on ne peut relire les locos que sur la voie de programmation, donc il faut s’en contenter. Pour le test, utilisons un analyseur de trame sur Arduino qui monitore tout ce qui passe en DCC. La fonction programmation des CV accessoires en POM reste intéressante si cela ne demande pas un trop gros effort d’écriture. On pourrait se limiter de 512 accessoires pour simplifier. Voir la page Internet de mon ami Michel. Par comparaison avec une trame loco, dans la trame 6 octets pour 512 accessoires, un bit change dans l’octet 1 et seul l’octet 2 est différent, les autres sont identiques. Par contre je ne connais pas la trame 2048 accessoires.
Ferroviairement, Philippe38Voir en ligne : PROGRAMMATION de 510 DÉCODEURS
Bibliothèque DCCpp 13 mars 2019 14:54, par dlal
J ai juste commencé à utiliser cette bibliothèque, avec le premier example autotest, tout était comme prévu. Dans le seconde example, minidcc, je reçois erreur 1 durant la compilation carte mega’.La seule chose sue j ai changé était l adresse de la loco, 13 au lieu de 3.....
Merci pour votre réponses -
Bibliothèque DCCpp 13 mars 2019 15:33, par Thierry
Pouvez vous préciser la nature de l’erreur ? Pendant la compilation, ou l’envoi vers le Mega ? A quelle ligne ? Tout ça est dit dans la fenêtre du bas de l’IDE... Sinon je ne peux pas faire grand chose avec juste un ’Ça marche pas !’...
Bibliothèque DCCpp 13 mars 2019 16:00, par dlal
Bonjour Thierry, merci pour votre réponse. L erreur apparaît pendant la premiere phase de vérification ( notée par v sur arduino).le message exact que je reçois est apparu à la fenetre en bas, est
exit status 1
, erreur pendant la compilation pour la carte arduino mega.
Merci pour encore une fois.
Denis-
Bibliothèque DCCpp 13 mars 2019 17:26, par Jean-Luc
Les informations pertinentes sont autour de ce
exit status 1
. Pouvez vous copier-coller tout ce qui est affiché en rouge en cliquant sur le bouton « Recopier les messages d’erreur » ? -
Bibliothèque DCCpp 13 mars 2019 17:31, par Thierry
Ce que vous me dites ne me sert à rien, c’est tout le reste du texte qui est utile.... Bref si vous compilez comme je le crois, vous devez avoir un texte qui ressemble à
Arduino : 1.8.7 (Windows 10), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
MiniDcc:7:24 : error : Commanders.h : No such file or directory
compilation terminated.
exit status 1
Commanders.h : No such file or directory"No such file or directory" signifie qu’il vous manque un fichier, ici Commanders.h, ce qui est probablement le cas si vous n’avez pas installé la bibliothèque Commanders utilisée dans cet exemple. C’est ce que je dis dans l’article associé à DCCpp que je vous enjoins de lire attentivement.
Bibliothèque DCCpp 13 mars 2019 17:34, par dlal
Bonsoir Thierry,
Voila ce que je recoie,
merci ,
Arduino:1.8.8 (Windows 10), Scheda :"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"In file included from C :\Users\anton\Documents\Arduino\MiniDcc\MiniDcc.ino:7:0 :
C :\Users\anton\Documents\Arduino\libraries\Commanders\src/Commanders.h:470:18 : fatal error : DIO2.h : No such file or directory
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.Questo report potrebbe essere più ricco di informazioni abilitando l’opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni" -
Bibliothèque DCCpp 13 mars 2019 17:41, par dlal
merci Thierry,resolu il manque DIO2
Denis -
Bibliothèque DCCpp 24 avril 2019 22:28, par Philippe38
Hi Trusty,
Tu as laissé trainer 2 fichiers de chez Atani dans DCCpp.zip. Ils n’ont rien à faire là, je croyais que j’avais déplacé ces fichiers par erreur mais ils sont bien dans ton zip. Est ce qu’il est envisageable de séparer la gestion du courant entre Main et Prog pour éviter de couper inutilement la voie de programmation en cas de court-circuit sur Main ? Dans le même esprit, je souhaiterai ajouter 3 boosters contrôlés indépendamment mais je n’ose pas modifier le soft parce je ne le connais pas assez bien. Et il me faudrait le modifier à chaque release.
Bibliothèque DCCpp 4 juin 2019 18:02, par Thierry
Tu as raison pour les deux fichiers, mais je dois m’attaquer à la version ESP32 incessamment, je vais les laisser en attendant. J’ai ajouté des arguments à powerOn() et powerOff() pour couper/restaurer le courant sur les deux voies séparément. Mais en fait c’est une vraie gestion de boosters qu’il faudrait, avec une classe dédiée qui s’occuperai de la gestion du courant. En attendant, j’ai fait une version spécifique de la classe CurrentMonitor pour mieux gérer les court-circuits indépendamment. Cette version permettrai aussi d’ajouter des moniteurs sur chaque booster :
/********************************************************************** CurrentMonitor.h COPYRIGHT (c) 2013-2016 Gregg E. Berman Part of DCC BASE STATION for the Arduino **********************************************************************/ #ifdef ARDUINO_ARCH_AVR #ifndef CurrentMonitor_h #define CurrentMonitor_h /** Factor to smooth the result...*/ #define CURRENT_SAMPLE_SMOOTHING 0.01 /** Time between two measurements. @remark Millis() uses TIMER-0. For UNO, we change the scale on Timer-0. For MEGA we do not. This means CURRENT_SAMPLE_TIME is different for UNO then MEGA. */ #if defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_NANO) // Configuration for UNO #define CURRENT_SAMPLE_TIME 10 #else // Configuration for MEGA #define CURRENT_SAMPLE_TIME 1 #endif /** This structure/class describes a current monitor.*/ struct CurrentMonitor{ static long int sampleTime; /**< time elapsed since last measurement. This delay is common to all monitors. */ int pin; /**< Attached check pin.*/ int signalPin; /**< signal pin.*/ float currentSampleMax; /**< Value of the maximum current accepted without problem.*/ float current; /**< Value of the last measured current.*/ const char *msg; /**< Message to send when excessive current is measured.*/ /** begin function. @param pin Attached pin. UNEFINED_PIN to inactivate this monitor. @param inSignalPin Pin to set LOW if a shortcut is detectexd. @param msg Message to send to console when a smoothed current value greater than maximum is detected. @param inSampleMax Maximum value of the current. Default is 300. */ void begin(int pin, int inSignalPin, const char *msg, float inSampleMax = 300); /** Checks if sufficient time has elapsed since last update. Common to all monitors. */ static boolean checkTime(); /** Checks the current on this monitor. */ void check(); }; #endif #endif
Noter le signalPin apparu dans la classe et le begin(), qui correspond à la broche à mettre à LOW si un problème intervient. Et
/********************************************************************** CurrentMonitor.cpp COPYRIGHT (c) 2013-2016 Gregg E. Berman Part of DCC BASE STATION for the Arduino **********************************************************************/ #include "Arduino.h" #ifdef ARDUINO_ARCH_AVR #include "DCCpp_Uno.h" #include "CurrentMonitor.h" #include "Comm.h" /////////////////////////////////////////////////////////////////////////////// void CurrentMonitor::begin(int pin, int inSignalPin, const char *msg, float inSampleMax) { this->pin = pin; this->signalPin = inSignalPin; this->msg = msg; this->current = 0; this->currentSampleMax = inSampleMax; } // CurrentMonitor::begin boolean CurrentMonitor::checkTime() { if(millis( ) - sampleTime < CURRENT_SAMPLE_TIME) // no need to check current yet return(false); sampleTime = millis(); // note millis() uses TIMER-0. For UNO, we change the scale on Timer-0. For MEGA we do not. This means CURENT_SAMPLE_TIME is different for UNO then MEGA return(true); } // CurrentMonitor::checkTime void CurrentMonitor::check() { if (this->pin == UNDEFINED_PIN) return; this->current = (float)(analogRead(this->pin) * CURRENT_SAMPLE_SMOOTHING + this->current * (1.0 - CURRENT_SAMPLE_SMOOTHING)); // compute new exponentially-smoothed current // current overload and Programming Signal is on (or could have checked Main Signal, since both are always on or off together) if (this->current > this->currentSampleMax && digitalRead(this->signalPin) == HIGH) { digitalWrite(this->signalPin, LOW); DCCPP_INTERFACE.print(this->msg); // print corresponding error message #if !defined(USE_ETHERNET) DCCPP_INTERFACE.println(""); #endif } } // CurrentMonitor::check long int CurrentMonitor::sampleTime=0; #endif
Noter la fonction check() qui utilise maintenant cette signalPin pour couper le courant. Il faut aussi modifier DCCpp.cpp pour ajouter l’argument manquant du begin.
void DCCpp::beginMain(uint8_t inOptionalDirectionMotor, uint8_t inSignalPin, uint8_t inSignalEnable, uint8_t inCurrentMonitor) { ... mainMonitor.begin(DCCppConfig::CurrentMonitorMain, DCCppConfig::SignalEnablePinMain, (char *) "<p2>"); ... } void DCCpp::beginProg(uint8_t inOptionalDirectionMotor, uint8_t inSignalPin, uint8_t inSignalEnable, uint8_t inCurrentMonitor) { ... progMonitor.begin(DCCppConfig::CurrentMonitorProg, DCCppConfig::SignalEnablePinProg, (char *) "<p3>"); ... } void DCCpp::begin() { ... mainMonitor.begin(UNDEFINED_PIN, UNDEFINED_PIN, ""); progMonitor.begin(UNDEFINED_PIN, UNDEFINED_PIN, ""); ... }
Ajouter des boosters reviendrait à ajouter de nouvelles instances de la classe avec les pins qui vont bien pour couper le courant juste chez eux si un problème survient.
Je n’ai pas poussé ces modifications dans la bibliothèque officielle d’aujourd’hui parce que je n’ai pas pu tester. Si tu peux le faire, dis moi si ça marche...
Bibliothèque DCCpp 7 juin 2019 22:32, par Philippe38
Bravo et bon début, ça fonctionne bien pour la voie principale qui se coupe sans action sur la voie de programmation. En cas de court-circuit sur la voie principale, elle seule est interrompue par l’Arduino.
Cependant je n’ai pas réussi à couper le DCC en faisant un court-circuit sur la voie de programmation ! Je vais voir pourquoi.
Maintenant vient la gestion du PowerOff() avec qui nécessite un nouveau paramètre pour couper individuellement le DCC d’une voie sans couper le DCC des autres voies. Et la même chose pour PowerOn(). C’est en pratiquant qu’on se rend compte du besoin.
Il faut pouvoir régler l’intensité maxi admise sur chaque circuit mais on peut se satisfaire de 2 valeurs : une pour les voies principales et une pour la voie de programmation. Encore quelques changements et ça sera parfait pour pouvoir ajouter d’autres districts. Je propose de ne pas toucher P0 à P3 mais d’individualiser en ajoutant P4 et P5, et ainsi de suite. Ce serait des options neutres si inutilisées et le tout reste compatible avec ce qui existe déjà. Pour la déclaration, on a juste besoin d’une pin Enable par nouveau district. Je continue les tests. -
Bibliothèque DCCpp 8 juin 2019 15:01, par Philippe38
Dans CurrentMonitor.cpp au milieu de la ligne 42, il me semble qu’un + à disparu.
Bibliothèque DCCpp 8 juin 2019 17:15, par Thierry
Oui, exact, mais mon code est bon. C’est l’afficheur du forum qui doit l’avoir interprété comme autre chose... En tout cas, il y a bien un ’+’, et s’il n’y est pas, il faut l’ajouter. J’ai corrigé mon post précédent.
Bibliothèque DCCpp 11 juin 2019 18:00, par Lormedy
DCCpp intègre le bus S88 dans l’Arduino :
Comme la rétro-signalisation manquait dans la bibliothèque DCCpp de Thierry, j’ai ajouté le code qui gère la rétro-signalisation S88 et j’ai nommé le tout : DCCpp_S88. J’ai intégré la lecture directe du simplissime bus S88 sans qu’il soit nécessaire de passer par un quelconque boitier d’interface supplémentaire. Un seul Arduino suffit pour générer le DCC, piloter les aiguillages et les feux, et maintenant lire jusqu’à 512 capteurs grâce au bus S88. Naturellement j’ai rendu cette interface logicielle du bus S88 compatible avec les logiciels libres comme CDM-Rail, CDT30, JMRI et Rocrail. Je n’ai pas testé avec d’autres logiciels mais j’ai testé 2 types de cartes de rétro-signalisation différentes.
Adieu aux forêts de fils qui partent de l’Arduino, un simple câble RJ45 suffit. Les infos des capteurs sont rassemblées sur place par une carte de rétro-signalisation puis transmises par le câble RJ45 vers la carte suivante et ainsi de suite le long du réseau jusqu’à l’Arduino. Le câble RJ45 du bus S88-N télé-alimente aussi les cartes, donc pas besoin d’alimenter séparément les cartes de rétro-signalisation. Sur le bus S88-N, ce logiciel permet le mélange des cartes à 8 entrées avec celles à 16 entrées.
Bibliothèque DCCpp 18 juin 2019 11:56, par Didier44
Bonjour » Thierry,
Je reviens vers DCCpp avec Ethernet et l’exemple EthernetDcc.ino.
J’utilise :#define USE_ETHERNET_WIZNET_5100
et
DCCpp::beginMainMotorShield(); DCCpp::beginProgMotorShield();
A la compilation, j’ai cette erreur :
..libraries\DCCpp\src\DCCpp_Uno.h:29:27: error: 'eServer' was not declared in this scope
#define DCCPP_INTERFACE eServer
J’imagine que tu as développé un serveur quelque part pour tes essais.
En remplaçant eServer par Serial cela ne passe pas non plus un peu plus loin : DCCpp.cpp ligne 345DCCPP_INTERFACE.begin();
Je ne retrouve pas trace de cette fonction ?
Si je supprime cette ligne alors RAS pour la compilation !Avec DCC++ j’utilise régulièrement pour mes essais une connexion Ethernet via un programme en C++ sur mon PC et tout va bien.
Avec DCCpp mon programme me renvoie :Error: "Socket operation timed out"
Et plus rien bien sur.
Bibliothèque DCCpp 19 juin 2019 18:04, par Thierry
Oui, c’est corrigé dans la 1.3.5 que je viens de mettre en ligne.
Ça vient de la volonté d’utiliser une macro pour savoir à qui envoyer les messages texte. En mode normal, c’est ’Serial’ qui est utilisé, mais en configuration Ethernet, c’est une variable globale ’eServer’ déclarée dans les sources de DCCpp. Pour que cette variable soit utilisable partout, il faut la déclarer ’extern’, et c’est ce qui est fait dans comm.h . Pourtant, dans les dernières modifs qui ont vu INTERFACE être remplacé par DCCPP_INTERFACE pour un problème de compilation ESP32 (ou VisualStudio, je ne sais plus...), j’ai précisément oublié cette ligne ’extern’. D’où la variable inconnue... -
Bibliothèque DCCpp 19 juin 2019 19:07, par Didier44
Merci Thierry pour a réponse mais j’ai toujours une erreur. Je précise que j’essaie simplement de compiler ton exemple EthernetDcc.ino avec ArduinoIDE. J’ai la même erreur avec Visual Studio Code !
...\Temp\ccVIMcJT.ltrans0.ltrans.o : In function
main': <artificial>:(.text.startup+0x330): undefined reference to
eServer’ -
Bibliothèque DCCpp 19 juin 2019 21:03, par Thierry
Je savais bien que j’avais oublié quelque chose, la première chose que j’ai vue, en fait !
Dans l’exemple il faut remplacerEthernetServer INTERFACE(2560) ;
par
EthernetServer DCCPP_INTERFACE(2560) ;
Je repousserai une version corrigée sur le Git bientôt...
Bibliothèque DCCpp 20 juin 2019 10:31, par Didier44
Merci pour ta rapidité la compilation se fait correctement maintenant.
Bibliothèque DCCpp 20 juin 2019 23:14, par Lormedy
Suggestion : ce serait bien de créer une constante ou un #define pour déclarer ce port dans un fichier.h global afin de pouvoir le changer facilement sans avoir à parcourir tous les fichiers à la recherche de variables disséminées dans les différents fichiers du projet. C’est valable pour toute variable de configuration.
Bibliothèque DCCpp 21 juin 2019 11:43, par Jean-Luc
Oui,
Ça serait intéressant de pouvoir paramétrer une bibliothèque de cette façon. Malheureusement, et sauf erreur de ma part, lors de la compilation d’une bibliothèque, le répertoire du sketch n’est pas dans les chemins d’inclusion. Il y a d’ailleurs une issue à ce propos qui est ouverte depuis presque 4 ans.
Bibliothèque DCCpp et écran LCD 27 juin 2019 13:17, par Juan
Bonjour, Thierry,
Je commence avec l’Arduino et il est clair pour moi que je vais construire ma central sur la base de votre fantastique bibliothèque DCCpp.
J’ai déjà fait quelques progrès et j’ai un premier prototype qui fonctionne parfaitement. Mais maintenant j’ai un doute : j’aime beaucoup l’écran LCD décrit par Dominique dans "Comment piloter trains et accessoires en DCC avec un Arduino (4).
La question est : comment puis-je implémenter cet écran et ses fonctionnalités avec la bibliothèque DCCpp ?Merci beaucoup,
Juan.Traduit avec www.DeepL.com/Translator
Bibliothèque DCCpp 27 juin 2019 19:10, par msport
si vous voulez mettre en œuvre un écran LCD 16x02, vous avez au moins deux réalisations qui fonctionnent très bien en autonome (mais pas seulement) :
et
http://locoduino.org/spip.php?article232-
Bibliothèque DCCpp 28 juin 2019 09:00, par Juan
Merci beaucoup, je vais étudier attentivement ces deux montages.
Salutations,
Juan.
Bibliothèque DCCpp 17 juillet 2019 19:05, par Juan
Bonsoir Thierry,
J’ai un problème "sérieux" : je ne peux pas installer la bibliothèque DCCpp sur mon Mega arduino, j’obtiens un message d’erreur. Les lignes rouges de l’erreur sont les suivantes (je ne sais pas comment inclure un fichier avec le message complet) :
C :\Users\Juan\AppData\Local\Temp\cc0MK6Hl.ltrans0.ltrans.o : In functionmain': <artificial>:(.text.startup+0x628): undefined reference to
eServer’:(.text.startup+0x62a) : undefined reference to
eServer' <artificial>:(.text.startup+0x840): undefined reference to
eServer’:(.text.startup+0x842) : undefined reference to
eServer' <artificial>:(.text.startup+0x1700): undefined reference to
eServer’C :\Users\Juan\AppData\Local\Temp\cc0MK6Hl.ltrans0.ltrans.o : :(.text.startup+0x1702) : more undefined references to `eServer’ follow
Usando librería DCCpp con versión 1.3.5 en la carpeta : C :\Users\Juan\Documents\Arduino\libraries\DCCpp
Usando librería Ethernet con versión 2.0.0 en la carpeta : C :\Program Files (x86)\Arduino\libraries\Ethernet
Usando librería EEPROM con versión 2.0 en la carpeta : C :\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM
Usando librería SPI con versión 1.0 en la carpeta : C :\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compilando para la tarjeta Arduino/Genuino Mega or Mega 2560.Merci par votre temps.
Juan.-
Bonjour. c’est un problème que j’ai déjà corrigé. Récupérez le dernière version de la bibliothèque, cela devrait résoudre le problème.
Bibliothèque DCCpp 17 juillet 2019 21:46, par Juan
Mais je pense que c’est précisément la dernière version que j’utilise, que je viens de télécharger depuis le depôt Locoduino.
Bibliothèque DCCpp 23 juillet 2019 09:56
Dans ce cas, c’est que #define NO_ETHERNET n’est pas en remarque alors qu’il devrait... Désolé pour le délai, mais je suis en vacances loin de mon pc ...
Bibliothèque DCCpp 24 juillet 2019 18:05, par Juan
Bonjour, Thierry,
Pas de problème, je suis désolé de vous déranger en vacances.
La bibliothèque de DCCpp se porte si bien que ça. Et j’ai beaucoup d’autres questions sur la Commanders, mais nous ferions mieux de les laisser pour votre retour.
Profitez des vacances et "oubliez" le PC.
Juan -
Bibliothèque DCCpp 8 août 2019 19:16, par Juan
Bonjour, Tiherry,
Une question sur ton retour de vacances. J’essaie de contrôler DCC+++ via Bluetooth avec le module HC-06.
Pas de problème si je connecte le module aux broches 0 et 1 du Uno ou du Mega. Mais bien sûr, je perds la connexion par le moniteur sérial. J’essaie d’utiliser d’autres pies, mais ça ne marche pas pour moi. Comment faire cette connexion sans perdre l’USB ?Je vous remercie beaucoup,
Juan
Bibliothèque DCCpp 8 août 2019 20:23, par Thierry
Le Nano ne possède qu’une seule interface série effectivement utilisée par l’USB, mais il est possible d’en créer une de toutes pièces par logiciel avec les bibliothèques SoftwareSerial, AltSoftSerial ou NeoSWSerial. Attention toutefois à l’usage des timers et des interruptions par ces bib, alors que DCC++ en utilise aussi. Il ne faut pas qu’il y ai de collision...
Pour plus de sécurité, il reste la possibilité d’utiliser un circuit extérieur raccordé en SPI ou en I2C à l’Arduino. Je n’en ai pas trouvé chez mes marchands habituels, mais je ne cherche peut être pas avec les bons mots clés...-
Bibliothèque DCCpp 8 août 2019 20:33, par Juan
Merci beaucoup pour votre réponse rapide. Le Nano et Uno n’ont qu’une seule interface série, mais j’utilise le Mega, qui je pense a quatre interfaces. Et il n’y a aucune chance que ça marche, vu mes courtes lumières sur le sujet, bien sûr.
Bibliothèque DCCpp 8 août 2019 23:41, par Juan
Dernières nouvelles : J’ai fait que cela fonctionne parfaitement dans la Mega.
Mais avec Uno, ça ne marche toujours pas.
Il sera nécessaire de continuer les recherches.
Bonne nuit.
Juan.
Bibliothèque DCCpp 30 octobre 2019 12:16, par Juan
Bonjour, Thierry.
J’ai terminé la première étape de mon modèle d’essai, qui consiste en un circuit simple avec deux aiguillages, plus plusieurs lumières et du son.
Ce que je propose dans un deuxième stade, c’est de monter les détecteurs de présence, pour pouvoir gérer le modèle automatiquement. Le circuit est déjà préparé avec les cantons correspondants. Et j’ai différents types de détecteurs d’occupation, mais ce dont je n’ai aucune idée, c’est du logiciel que je dois implémenter.Mais je ne sais pas par où commencer. Que me conseillez-vous ? quel logiciel dois-je ajouter pour travailler avec votre bibliothèque DCCpp ?
Merci bien,
Juan -
Bibliothèque DCCpp 14 novembre 2019 19:41, par Juan
Bonne nuit, Thierry,
Une petite question : comment puis-je lire l’état, d’un aiguilage particulier, ?
Juan. -
Bibliothèque DCCpp 16 novembre 2019 10:52, par thierry
Bonjour. Si on parle d’une instance de la classe Turnout, il y a une méthode ’isActivated()’ qui renvoie true ou false selon le sens de l’aiguille. Je n’ai pas contre rien trouvé dans la syntaxe texte de DCC++ qui permette de connaitre l’état d’un turnout. Du coup dans la prochaine version de DCCpp il y aura une syntaxe où n est le numéro du turnout à interroger, ce qui renverra ou selon le sens.
Bibliothèque DCCpp 16 novembre 2019 10:59, par thierry
oups, la syntaxe DCC++n n’est pas passée... Donc la nouvelle commande serait "t n -1" (remplacer les guillemets par les caractères inférieur et supérieur), et le retour "H n 0" ou "H n 1".
Bibliothèque DCCpp 16 novembre 2019 11:32, par Juan
Bonjour, Thierry,
Et merci beaucoup pour votre réponse. Permettez-moi d’expliquer mon problème : dans ma centrale, avec votre bibliothèque DCC++ je fais un TCO graphique, dans un autre arduino connecté en série et chargé de gérer un écran TFT 3.5". J’ai branché des détecteurs de courant comme inputs, qui agissent comme des senseurs qui me disent quel canton est occupé.
Tout cela fonctionne parfaitement (à ma grande surprise), ce qui me manque, c’est de manipuler les aiguilages. C’est-à-dire, savoir si une aiguilage est ouverte ou fermée, pour envoyer l’ordre correspondant à l’arduino eslave.Merci beaucoup pour votre aide,
Juan.
Bibliothèque DCCpp 16 novembre 2019 13:39, par Thierry
Mais c’est DCC++ qui change la position des aiguillages ou c’est autre chose ?
Bibliothèque DCCpp 16 novembre 2019 18:06, par Juan
C’est vrai, nous devons être précis. La centrale est géré avec le sketch SerialDcc.ino de votre bibliothèque DCCpp, et les aiguillages sont gérés avec des commandes série de manière standard : , par exemple. Ce dernier "1" est l’état de la aiguilage, précisément celui que je veux récupérer.
Je ne sais pas si je m’explique bien.-
Bibliothèque DCCpp 16 novembre 2019 18:09, par Juan
Erreur, la commande série est de la forme "T 12, 1", voilà ce que je voulais dire.
Bibliothèque DCCpp 16 novembre 2019 18:12, par Juan
Ou pour faciliter les choses, supposons que les aiguillages soient traités par Rocrail.
Bibliothèque DCCpp 18 novembre 2019 10:25, par thierry
Donc c’est bien DCCpp qui change la position des aiguillages parce que quelqu’un donne un ordre texte pour ça. Dans ce cas, je reviens sur ma précédente réponse : il n’y a rien de prévu par DCC++ pour retourner l’état courant d’un aiguillage. La prochaine version de DCCpp améliorera ça, mais elle risque de ne pas arriver très vite...
Bibliothèque DCCpp 19 novembre 2019 21:54, par Juan
Bonne nuit.
Merci pour votre message, mais je ne suis pas d’accord avec le contenu : je pense qu’il est possible de retrouver l’état d’une aiguillage. En fait, je l’ai déjà fait, bien que partiellement. Je continue mes recherches, quand j’aurai perfectionné la méthode, je vous le ferai savoir, si vous êtes intéressé.
Salutations,
Juan.
Bibliothèque DCCpp 2 décembre 2019 17:33, par Juan
Bonjour, Thierry,
J’ai été occupé et je n’ai pas pu répondre à ces messages.
Pour revenir au dernier sujet, je vous envoie ici la petite modification que j’ai faite dans "Tounout.cpp" :
#ifdef USE_TEXTCOMMAND
DCCPP_INTERFACE.print(" DCCPP_INTERFACE.print(data.id) ;
#ifdef USE_BLUETOOTH
BLUETOOTH.print(" BLUETOOTH.print(data.id);
if (data.tStatus == 0){
DCCPP_INTERFACE.print(" 0>") ;
// Serial3.write(’x’) ; // Prueba para la TFT
BLUETOOTH.print(" 0>") ;
else
DCCPP_INTERFACE.print(" 1>") ;
// Serial3.write(’z’) ; // Prueba para la TFT
BLUETOOTH.print(" 1>") ;
#endifAvec cette modification, quand j’active ou désactive l’aiguillage, le caractère "x" ou "z" est envoyé à Serial3, pour que je puisse obtenir quelque chose comme ceci :
"Tournout 1 = open", or "Tournout 1 = closed".
Comme je l’ai dit, ça marche parfaitement dans mon cas, où il n’y a qu’une seul aiguillage.
Ce que je ne sais pas encore faire, c’est faire plusieurs aiguillages.
Salutations
Juan. -
Bibliothèque DCCpp 3 décembre 2019 20:30
Oui, on est donc d’accord. Il n’y a rien dans DCC++ qui retourne l’état d’un aiguillage. Il faut modifier le code pour y arriver.
Bibliothèque DCCpp 18 janvier 2020 17:23, par CLB89
Nouveau sur le site Locoduino et ses multiples applications, je suis très intéressé par Votre article sur DCCpp et sa mise en oeuvre. Je l’ai donc lu et relu et ai décidé de me lancer dans une expérimentation aussi simple que possible.Matériel : JMRI sur W10 en liaison USB/série avec un Arduino Mega 2560. Je me suis limité à USE_TURNOUT, USE_TEXTCOMMAND et j’ai utilisé votre exemple Série en le simplifiant à l’extrême, c’est à dire :# include "DCCpp.h" void setup() { Serial.begin(115200) } void loop() { DCCpp::loop() }
La compilation de l’DE Arduino bloque rapidement m’indiquant " Erreur de compilation pour la carte Arduino Mega". Quelle serait votre recommandation pour aller plus loin ?
Merci par avance !-
Bibliothèque DCCpp 18 janvier 2020 22:40, par Jean-Luc
si c’est bien le code que vous avez tenté de compiler, il manque les points virgule à la fin des lignes 5 et 10.
cordialement.
Bibliothèque DCCpp 19 janvier 2020 09:13, par CLB89
Merci de votre réponse !
Nouveau sur Locoduino, je ne sais pas envoyer en ligne une copie d’écran ! Apparemment l’editeur d’envoi des messages supprime les caractères du type ALTGr 123 (), AltGr 125 () et autres signes de ponctuation comme le point virgule. Ces catactères font bien partie de mon script.
Bibliothèque DCCpp 18 janvier 2020 18:46
Il y a d’autres messages avant celui ci. Pouvez vous les donner ? Ce qui est souvent le plus important est la première erreur. Les autres n’en sont qu’une conséquence...-
Bibliothèque DCCpp 19 janvier 2020 09:19, par CLB89
Non pas d’autre message ! Ceci arrive durant la compilation de l’IDE et s’inscrit en bas et en rouge dans la fenêtre de l’IDE.Cordialement
Bibliothèque DCCpp 19 janvier 2020 09:53, par msport
il y a un ascenseur à droite et qui plus est, la fenêtre est redimensionnable ...
Bibliothèque DCCpp 19 janvier 2020 10:00
A la fin de la compilation, lorsque des erreurs apparaissent, un bouton ’recopier les messages d’erreur’ apparaît tout à droite de la zone orange entre le code et ces messages. Appuyez sur ce bouton puis coller cela ici... C’est impossible de diagnostiquer quoi que ce soit sans ça.
Autre possibilité : le message ’CANNOT COMPILE - DCC++ ONLY WORKS WITH AN ARDUINO UNO OR AN ARDUINO MEGA 1280/2560’ qui apparaît lorsque l’IDE est paramétré pour compiler pour autre chose qu’un Uno ou un Mega... -
Bibliothèque DCCpp 17 février 2020 16:59, par CLB89
J’ai toujours beaucoup de problèmes dans la mise en oeuvre de DCCpp. Je suis passé à une connexion Ethernet. Mon croquis est le suivant :/************************************************************* project: <Dc/Dcc Controller> author: <Thierry PARIS> description: <Dcc Ethernet Controller sample> *************************************************************/ #include "DCCpp.h" #if !defined(USE_TEXTCOMMAND) || !defined(USE_ETHERNET) #error To be able to compile this sample,the lines #define USE_TEXTCOMMAND and #define USE_ETHERNET must be uncommented in DCCpp.h #endif // the media access control (ethernet hardware) address for the shield: uint8_t mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x76, 0xB6 }; //the IP address for the shield: uint8_t ip[] = { 192, 168, 1, 14 }; EthernetServer DCCPP_INTERFACE(2560); // Create and instance of an EthernetServer void setup() { pinMode(53, OUTPUT); digitalWrite(53, HIGH); pinMode(4, OUTPUT); digitalWrite(4, HIGH); Serial.begin(9600); DCCpp::begin(); // Configuration for my LMD18200. See the page 'Configuration lines' in the documentation for other samples. // DCCpp::beginMain(UNDEFINED_PIN, DCC_SIGNAL_PIN_MAIN, 3, A0); DCCpp::beginEthernet(mac, ip, EthernetProtocol::TCP); Serial.print("DCCpp démarre et Internet est supposé lancé"); Serial.println(); } void loop() { DCCpp::loop(); }
Arduino : 1.8.13 Hourly Build 2020/02/14 03:33 (Windows 10), Carte : "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)" C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:30:6: error: 'Output' has not been declared void Output::begin(int id, int pin, int iFlag) { ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void begin(int, int, int)': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:37:6: error: 'firstOutput' was not declared in this scope if (firstOutput == NULL) { ^~~~~~~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:38:17: error: invalid use of 'this' in non-member function firstOutput = this; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:40:12: error: 'get' was not declared in this scope else if ((get(id)) == NULL) { ^~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:40:12: note: suggested alternative: 'gets' else if ((get(id)) == NULL) { ^~~ gets C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:3: error: 'Output' was not declared in this scope Output *tt = firstOutput; ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:3: note: suggested alternative: 'Outputs_h' Output *tt = firstOutput; ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:41:11: error: 'tt' was not declared in this scope Output *tt = firstOutput; ^~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:44:20: error: invalid use of 'this' in non-member function tt->nextOutput = this; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:48:2: error: invalid use of 'this' in non-member function this->set(id, pin, iFlag); ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:60:6: error: 'Output' has not been declared void Output::set(int id, int pin, int iFlag) { ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void set(int, int, int)': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:61:2: error: invalid use of 'this' in non-member function this->data.id = id; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:62:2: error: invalid use of 'this' in non-member function this->data.pin = pin; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:63:2: error: invalid use of 'this' in non-member function this->data.iFlag = iFlag; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:64:2: error: invalid use of 'this' in non-member function this->data.oStatus = 0; ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:2: error: invalid use of 'this' in non-member function this->data.oStatus = bitRead(this->data.iFlag, 1) ? bitRead(this->data.iFlag, 2) : 0; ^~~~ In file included from C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:9:0: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:31: error: invalid use of 'this' in non-member function this->data.oStatus = bitRead(this->data.iFlag, 1) ? bitRead(this->data.iFlag, 2) : 0; ^ C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:111:32: note: in definition of macro 'bitRead' #define bitRead(value, bit) (((value) >> (bit)) & 0x01) ^~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:67:62: error: invalid use of 'this' in non-member function this->data.oStatus = bitRead(this->data.iFlag, 1) ? bitRead(this->data.iFlag, 2) : 0; ^ C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:111:32: note: in definition of macro 'bitRead' #define bitRead(value, bit) (((value) >> (bit)) & 0x01) ^~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:15: error: invalid use of 'this' in non-member function digitalWrite(this->data.pin, this->data.oStatus ^ bitRead(this->data.iFlag, 0)); ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:31: error: invalid use of 'this' in non-member function digitalWrite(this->data.pin, this->data.oStatus ^ bitRead(this->data.iFlag, 0)); ^~~~ In file included from C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:9:0: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:71:60: error: invalid use of 'this' in non-member function digitalWrite(this->data.pin, this->data.oStatus ^ bitRead(this->data.iFlag, 0)); ^ C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:111:32: note: in definition of macro 'bitRead' #define bitRead(value, bit) (((value) >> (bit)) & 0x01) ^~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:75:10: error: invalid use of 'this' in non-member function pinMode(this->data.pin, OUTPUT); ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:80:6: error: 'Output' has not been declared void Output::activate(int s){ ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void activate(int)': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:81:3: error: 'data' was not declared in this scope data.oStatus=(s>0); // if s>0, set status to active, else inactive ^~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:81:3: note: suggested alternative: 'atan' data.oStatus=(s>0); // if s>0, set status to active, else inactive ^~~~ atan C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:107:1: error: 'Output' does not name a type; did you mean 'Outputs_h'? Output* Output::get(int n){ ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:114:6: error: 'Output' has not been declared void Output::remove(int n){ ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void remove(int)': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:3: error: 'Output' was not declared in this scope Output *tt,*pp; ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:3: note: suggested alternative: 'Outputs_h' Output *tt,*pp; ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:11: error: 'tt' was not declared in this scope Output *tt,*pp; ^~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:115:15: error: 'pp' was not declared in this scope Output *tt,*pp; ^~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:117:10: error: 'firstOutput' was not declared in this scope for(tt=firstOutput, pp = NULL;tt!=NULL && tt->data.id!=n;pp=tt,tt=tt->nextOutput); ^~~~~~~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:129:10: error: 'firstOutput' was not declared in this scope if(tt==firstOutput) ^~~~~~~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:146:5: error: 'Output' has not been declared int Output::count() { ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'int count()': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:2: error: 'Output' was not declared in this scope Output *tt; ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:2: note: suggested alternative: 'Outputs_h' Output *tt; ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:148:10: error: 'tt' was not declared in this scope Output *tt; ^~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:149:12: error: 'firstOutput' was not declared in this scope for (tt = firstOutput; tt != NULL; tt = tt->nextOutput) ^~~~~~~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:220:6: error: 'Output' has not been declared void Output::parse(char *c){ ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: In function 'void parse(char*)': C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:3: error: 'Output' was not declared in this scope Output *t; ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:3: note: suggested alternative: 'Outputs_h' Output *t; ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:222:11: error: 't' was not declared in this scope Output *t; ^ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:227:9: error: 'get' was not declared in this scope t=get(n); ^~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:227:9: note: suggested alternative: 'set' t=get(n); ^~~ set C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:240:7: error: 'create' was not declared in this scope create(n,s,m); ^~~~~~ C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:240:7: note: suggested alternative: 'rename' create(n,s,m); ^~~~~~ rename C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp: At global scope: C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:257:1: error: 'Output' does not name a type; did you mean 'Outputs_h'? Output *Output::create(int id, int pin, int iFlag){ ^~~~~~ Outputs_h C:\Users\claud\OneDrive\Documents\Arduino\libraries\DCCpp\src\Outputs.cpp:312:1: error: 'Output' does not name a type; did you mean 'Outputs_h'? Output *Output::firstOutput=NULL; ^~~~~~ Outputs_h exit status 1 Erreur de compilation pour la carte Arduino Mega or Mega 2560 Ce rapport pourrait être plus détaillé avec l'option "Afficher les résultats détaillés de la compilation" activée dans Fichier -> Préférences.
Ma sélection DCCpp.h est la suivante :// Inclusion area // #define USE_TURNOUT //#define USE_EEPROM //#define USE_OUTPUT #define USE_SENSOR #define USE_TEXTCOMMAND //#define USE_ETHERNET_WIZNET_5100 #define USE_ETHERNET_WIZNET_5500 //#define USE_ETHERNET_WIZNET_5200 //#define USE_ETHERNET_ENC28J60»
Claude -
Bibliothèque DCCpp 17 février 2020 20:52, par Thierry
Oui, je suis d’accord, il y a une erreur. Dans la bibliothèque, au début du fichier Outputs.cpp, remplacez ligne 13 le USE_TURNOUT par USE_OUTPUT et ça devrait beaucoup mieux marcher...
D’autre part, je vois que vous utilisez la version ’Hourly Build’ de l’IDE, je ne vous le conseille pas. Cette version est une version de travail pour l’équipe de développement. Ce n’est pas stable et peut planter et redevenir correcte à chaque heure... Et croyez moi, je développe tous les jours, c’est bien plus facile de faire une erreur que de ne pas en faire... Surtout lorsque les développeurs ne parlent pas la même langue et ne sont pas dans a même pièce ! La version officiuelle est la 1.8.12, et elle fonctionne bien pour l’instant...-
Bibliothèque DCCpp 18 février 2020 21:34, par CLB89
Merci pour votre prompte réponse et pour la clé qui m’a permis de rentrer dans le monde DCCpp ! Je compile désormais sans difficulté.
Quant à votre remarque sur l’utilisation de versions "beta", je suis tout à fait d’accord avec vous et je rentre dans le rang. La seule raison pour laquelle j’ai téléchargée la dernière "hourly build" est qu’il faut passer dans mon cas pour la version "officielle" par Microsoft Store, lequel en profite pour fabriquer un salmigondis d’exécutables de type "package" dans lequel on a beaucoup de difficultés à retrouver ses petits, en particulier en terme d’éléments de librairie.
Bibliothèque DCCpp 25 février 2020 18:17, par CLB89
Je reviens vers vous car j’ai toujours problème pour faire fonctionner JMRI avec mon sketch !
Mon sketch est le suivant :
project :
author :
description :
*************************************************************/#include "DCCpp.h"
#endif// the media access control (ethernet hardware) address for the shield :
uint8_t mac[] = 0xA8, 0x61, 0x0A, 0xAE, 0x76, 0xB6 ;
//the IP address for the shield :
// uint8_t ip[] = 192, 168, 1, 200 ;EthernetServer DCCPP_INTERFACE(2560) ; // Create and instance of an EthernetServer
// Set pins 53 & 4 as required with last Arduino Ethernet library + Ethernet V2 shield on Mega 2560
pinMode(53, OUTPUT) ;
digitalWrite(53, HIGH) ;
pinMode(4, OUTPUT) ;
digitalWrite(4, HIGH) ;Serial.begin(115200) ;
DCCpp::begin() ;
// Configuration for my "void Main". See the page ’Configuration lines’ in the documentation for other samples.
DCCpp::beginMain(UNDEFINED_PIN, UNDEFINED_PIN, UNDEFINED_PIN, UNDEFINED_PIN) ;
DCCpp::beginEthernet(mac, NULL, EthernetProtocol::TCP) ;
// Print the local IP address :
Serial.print("My IP address : ") ;
for (byte thisByte = 0 ; thisByte < 4 ; thisByte++)
// print the value of each byte of the IP address :
Serial.print(Ethernet.localIP()[thisByte], DEC) ;
Serial.print(".") ;
Serial.println() ;
Serial.println("DCCpp démarre et Ethernet est supposé opérationnel !") ;void loop()
DCCpp::loop() ;
»DHCP fonctionne et mon router voit bien Arduino et son Shield Ethernet V2. Après mise en route de JMRI et le chargement d’un panel très simple avec un circuit et 2 aiguillages, je retrouve dans le log session de JMRI l’information suivante :
« 2020-02-25 17:48:50,050 util.Log4JUtil INFO - ****** JMRI log ******* [main]
2020-02-25 17:48:50,061 util.Log4JUtil INFO - This log is appended to file : C :\Users\claud\JMRI\log\messages.log [main]
2020-02-25 17:48:50,061 util.Log4JUtil INFO - This log is stored in file : C :\Users\claud\JMRI\log\session.log [main]
2020-02-25 17:48:50,068 apps.Apps INFO - PanelPro version 4.18+R37ad3d0 starts under Java 1.8.0_241 on Windows 10 x86 v10.0 at Tue Feb 25 17:48:50 CET 2020 [main]
2020-02-25 17:48:50,293 apps.Apps INFO - Starting with profile CMBNewProfile.3e2b4aad [main]
2020-02-25 17:48:50,477 node.NodeIdentity INFO - Using 22ba0102-4f78-4270-a19c-71ebe7f6cd6b as the JMRI storage identity for profile id 3e2b4aad [AWT-EventQueue-0]
2020-02-25 17:48:50,667 dccpp.DCCppReply ERROR - DCCppReply value index too big. idx = 1 msg = iDCCpp LIBRARY BASE STATION FOR ARDUINO : V-2.0.0 / Feb 25 2020 17:35:02 [AWT-EventQueue-0]
2020-02-25 17:48:50,668 dccpp.DCCppReply ERROR - DCCppReply value index too big. idx = 2 msg = iDCCpp LIBRARY BASE STATION FOR ARDUINO : V-2.0.0 / Feb 25 2020 17:35:02 [AWT-EventQueue-0]
2020-02-25 17:49:01,018 util.FileUtilSupport INFO - File path program : is C :\Program Files (x86)\JMRI\ [main]
2020-02-25 17:49:01,018 util.FileUtilSupport INFO - File path preference : is C :\Users\claud\JMRI\CMBNewProfile.jmri\ [main]
2020-02-25 17:49:01,018 util.FileUtilSupport INFO - File path profile : is C :\Users\claud\JMRI\CMBNewProfile.jmri\ [main]
2020-02-25 17:49:01,019 util.FileUtilSupport INFO - File path settings : is C :\Users\claud\JMRI\ [main]
2020-02-25 17:49:01,019 util.FileUtilSupport INFO - File path home : is C :\Users\claud\ [main]
2020-02-25 17:49:01,019 util.FileUtilSupport INFO - File path scripts : is C :\Program Files (x86)\JMRI\jython\ [main]
2020-02-25 17:49:01,618 PanelPro.PanelPro INFO - Main initialization done [main]
2020-02-25 17:49:51,464 audio.JoalAudioFactory INFO - Initialised JOAL using OpenAL : vendor - OpenAL Community version - 1.1 ALSOFT 1.15.1 [Listed Table Generation]
2020-02-25 17:59:07,074 audio.DefaultAudioManager INFO - Shutting down active AudioFactory [AWT-EventQueue-0]
2020-02-25 17:59:07,188 managers.DefaultShutDownManager INFO - Normal termination complete [AWT-EventQueue-0] »Merci de votre aide,
Claude -
Bibliothèque DCCpp 29 février 2020 21:35, par CLB89
Bonsoir Thiéry,
Juste une mise à jour après de nouveaux essais :
1. Environnement : croquis inchangé, Arduino IDE 1.8.12, JMRI 4.18, Arduino Mega 2560 + Shield Ethernet V2, Configuration DCCpp.h :
« #define USE_EEPROM
//#define USE_SENSOR
//#define USE_ETHERNET_ENC28J60 ».2. Durant la compilation du croquis j’ai le message suivant :
« C :\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\utility/w5100.h:457:25 : warning : result of ’(256 << 8)’ requires 18 bits to represent, but ’int’ only has 16 bits [-Wshift-overflow=]
#define htons(x) ( (((x)<<8)&0xFF00) | (((x)>>8)&0xFF) )
^ »3. Le log session de JMRI contient les informations suivantes :
« 2020-02-29 15:41:41,208 util.Log4JUtil INFO - ****** JMRI log ******* [main]
2020-02-29 15:41:41,219 util.Log4JUtil INFO - This log is appended to file : C :\Users\claud\JMRI\log\messages.log [main]
2020-02-29 15:41:41,220 util.Log4JUtil INFO - This log is stored in file : C :\Users\claud\JMRI\log\session.log [main]
2020-02-29 15:41:41,227 apps.Apps INFO - PanelPro version 4.18+R37ad3d0 starts under Java 1.8.0_241 on Windows 10 x86 v10.0 at Sat Feb 29 15:41:41 CET 2020 [main]
2020-02-29 15:41:41,448 apps.Apps INFO - Starting with profile Mon_Réseau_JMRI.3e952548 [main]
2020-02-29 15:41:41,632 node.NodeIdentity INFO - Using 6fee769e-e147-4c16-8ee9-9d4a32c78f9c as the JMRI storage identity for profile id 3e952548 [AWT-EventQueue-0]
2020-02-29 15:41:41,817 dccpp.DCCppReply ERROR - DCCppReply value index too big. idx = 1 msg = iDCCpp LIBRARY BASE STATION FOR ARDUINO : V-2.0.0 / Feb 29 2020 15:39:56 [AWT-EventQueue-0]
2020-02-29 15:41:41,818 dccpp.DCCppReply ERROR - DCCppReply value index too big. idx = 2 msg = iDCCpp LIBRARY BASE STATION FOR ARDUINO : V-2.0.0 / Feb 29 2020 15:39:56 [AWT-EventQueue-0]
2020-02-29 15:41:52,082 util.FileUtilSupport INFO - File path program : is C :\Program Files (x86)\JMRI\ [main]
2020-02-29 15:41:52,082 util.FileUtilSupport INFO - File path preference : is C :\Users\claud\JMRI\Mon_Réseau_JMRI.jmri\ [main]
2020-02-29 15:41:52,083 util.FileUtilSupport INFO - File path profile : is C :\Users\claud\JMRI\Mon_Réseau_JMRI.jmri\ [main]
2020-02-29 15:41:52,083 util.FileUtilSupport INFO - File path settings : is C :\Users\claud\JMRI\ [main]
2020-02-29 15:41:52,083 util.FileUtilSupport INFO - File path home : is C :\Users\claud\ [main]
2020-02-29 15:41:52,083 util.FileUtilSupport INFO - File path scripts : is C :\Program Files (x86)\JMRI\jython\ [main]
2020-02-29 15:41:52,693 PanelPro.PanelPro INFO - Main initialization done [main]
2020-02-29 15:42:29,356 audio.JoalAudioFactory INFO - Initialised JOAL using OpenAL : vendor - OpenAL Community version - 1.1 ALSOFT 1.15.1 [Listed Table Generation]
2020-02-29 15:43:13,831 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message : T consecutive timeouts = 0 in network.DCCppEthernetPacketizer [network.DCCppEthernetPacketizer Transmit thread]
2020-02-29 15:43:18,832 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message : Z consecutive timeouts = 1 in network.DCCppEthernetPacketizer [network.DCCppEthernetPacketizer Transmit thread]
2020-02-29 15:51:28,411 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message : T consecutive timeouts = 0 in network.DCCppEthernetPacketizer [network.DCCppEthernetPacketizer Transmit thread]
2020-02-29 15:54:24,323 log.LogPanel ERROR - ---Send T command --- [AWT-EventQueue-0]
2020-02-29 15:54:26,842 log.LogPanel ERROR - ---Send T command --- [AWT-EventQueue-0]
2020-02-29 15:55:46,291 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message : T consecutive timeouts = 0 in network.DCCppEthernetPacketizer [network.DCCppEthernetPacketizer Transmit thread]
2020-02-29 16:01:05,370 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message : Z consecutive timeouts = 0 in network.DCCppEthernetPacketizer [network.DCCppEthernetPacketizer Transmit thread]
2020-02-29 16:02:46,099 audio.DefaultAudioManager INFO - Shutting down active AudioFactory [AWT-EventQueue-0]
2020-02-29 16:02:46,204 managers.DefaultShutDownManager INFO - Normal termination complete [AWT-EventQueue-0]
Claude -
Bibliothèque DCCpp < p3 > 23 mai 2020 16:33, par Lormedy
Suite à notre discussion de l’an dernier qui a conduit à séparer la détection des court-circuits entre MAIN et PROG, un aménagement vers la surveillance de plusieurs secteurs DCC (District in USA) sur un réseau s’avère nécessaire.
Avec DDCpp, lors d’un court-circuit sur la voie de programmation (Prog), la centrale DCCpp renvoie maintenant < p3 > vers le PC.
Cependant il serait plus judicieux de renvoyer < p4 > puisque logiquement DCCpp retourne < p0 > pour indiquer que le DCC est Offline et retourne < p2 > quand un court-circuit est détecté sur la voie principale ou sur activation du bouton panicStop.Il serait plus logique que les feedbacks de DCCpp qui commencent par < p suivi_d’un_nombre_pair > soient des indications d’arrêt du DCC.
Tous les feedbacks qui commencent par < p suivi_d’un_nombre_impair > seraient des indications de mise sous tension du DCC sur leur secteur de voies concernées.
Cela ouvrira la porte à la gestion future des différents secteurs qui composent un réseau, comme à la SNCF.
En résumé :
Seule la commande <0> avec son feedback < p0 > indiquerait un arrêt général du DCC sur tout le réseau à la demande du PC.
De même la commande <1> avec son feedback < p1 > indiquerait une mise sous tension générale du DCC sur tout le réseau à la demande du PC.
On peut donc envisager d’utiliser <3> pour mettre sous tension la voie de programmation seule, réponse < p3 >, et ainsi de suite avec un pas de 2.
Les autres commandes et feedbacks permettront de gérer d’autres secteurs de façon autonome, que les futurs logiciels prendront en compte.Merci de l’intégrer dans la prochaine release, < p4 > remplacerait < p3 > dans DCCpp.cpp vers la ligne 200.
Ferroviairement
Bibliothèque DCCpp 24 mai 2020 12:21, par souris verte
Ça veut dire que « le chef du réseau » commande plusieurs secteurs, via le CAN par exemple ?
Il envoie <1> et tous reçoivent l’ordre d’activer DCC puis lui répondent < p1>.
Le chef du réseau envoie <7>, le secteur 7 active DCC. Il réalise <1> et renvoie, via le CAN, < p7> au chef du réseau ?Pas simple cette affaire !?! Mais effectivement intéressant pour les grands réseaux 🤔
Le chef de réseau saura quels secteurs sont actifs et pourra réaliser les itinéraires en conséquence... bon courage M. le chef.
Bon dimanche
Yannick -
Bibliothèque DCCpp 4 octobre 2020 17:41, par Lionel
Tout d’abord un grand merci pour votre fabuleux travail et cette bibliothèque.
Je viens de mettre à jour celle-ci depuis la version 1.3.7 vers la dernière en date (la 1.4.1) et depuis, j’ai les erreurs de compilation ci-dessous (je n’ai pas changé mon programme entre temps), et du coup, impossible de l’utiliser.
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotive.cpp:10:1 : error : ’Locomotive’ does not name a type
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotive.cpp:25:1 : error : ’Locomotive’ does not name a type
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:10:1 : error : ’Locomotive’ does not name a type
Locomotive* Locomotives::pFirstLocomotive = NULL ;
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:11:6 : error : ’Locomotives’ has not been declared
bool Locomotives::useFunctionRegister = false ;
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:13:1 : error : ’Locomotive’ does not name a type
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:29:1 : error : ’Locomotive’ does not name a type
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:45:6 : error : ’Locomotives’ has not been declared
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:49:6 : error : ’Locomotives’ has not been declared
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp : In function ’void remove(const char*)’ :
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:49:6 : error : ambiguating new declaration of ’void remove(const char*)’
In file included from /home/lmollard/ArduinoIDE/hardware/arduino/avr/cores/arduino/Print.h:24:0,
from /home/lmollard/ArduinoIDE/hardware/arduino/avr/cores/arduino/Stream.h:26,
from /home/lmollard/ArduinoIDE/hardware/arduino/avr/cores/arduino/HardwareSerial.h:29,
from /home/lmollard/ArduinoIDE/hardware/arduino/avr/cores/arduino/Arduino.h:233,
from /home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:7 :
/home/lmollard/ArduinoIDE/hardware/tools/avr/avr/include/stdio.h:960:12 : note : old declaration ’int remove(const char*)’
extern int remove(const char *pathname) ;
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp : At global scope :
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:53:5 : error : ’Locomotives’ has not been declared
int Locomotives::count()
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp : In function ’int count()’ :
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:57:2 : error : ’Locomotive’ was not declared in this scope
Locomotive* pCurr = pFirstLocomotive ;
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:57:14 : error : ’pCurr’ was not declared in this scope
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:57:14 : note : suggested alternative : ’perror’
perror
/home/lmollard/Arduino/libraries/DCCpp/src/Locomotives/Locomotives.cpp:57:22 : error : ’pFirstLocomotive’ was not declared in this scope
^Auriez-vous une piste à me donner pour faire de nouveau fonctionner mon programme ?
Par avance, un grand merci pour votre aide.
Bonne journée,
Lionel -
Bibliothèque DCCpp 5 octobre 2020 08:31, par Thierry
C’est une erreur déjà corrigée, les fichiers Locomotive doivent être supprimés. Mais peut être que la dernière mise à jour n’a pas retiré les fichiers qui sont maintenant en trop...
Bibliothèque DCCpp 17 octobre 2020 11:50, par Dominique
Est-ce que DCCpp::loop() peut détecter des commandes texte arrivant via une liaison SotwareSerial sur un Nano ?
Dominique -
Bibliothèque DCCpp 17 octobre 2020 16:32, par Thierry
DCCpp fonctionne, comme DCC++, avec Serial par défaut, sans possibilité de facilement changer.
Par contre il est tout à fait envisageable de récolter des commandes sur une autre interface dans le loop() du croquis, à côté de DCCpp::loop(), et ensuite de demander le traitement de la commande avec TextCommand::parse(commande_recue) ; . -
Bibliothèque DCCpp 24 janvier 2021 12:39, par Denis
Je fais mes premiers pas dans votre biblioteque que je la trouve extrement utile a mes projets malgre le fait que je suis un neothyte, pourtant j’ espere...
Pour ce weekend je me suis implique sur le projet MiniDcc. Pour cette raison je voudrais savoir si le schema de branchement pour ce projet est disponible .
Je vous remercie d avance,
Denis -
Bibliothèque DCCpp 7 juin 2021 21:59, par Carlos
Salut ! je m’appelle Carlos, je travaille actuellement chez DCCppCab et j’aimerais entrer en contact avec quelqu’un du projet de bibliothèque DCCpp, pouvez-vous répondre à l’email d’inscription ? Merci !!!
Bibliothèque DCCpp 5 avril 2022 11:18, par CLB89
Toujours néophyte et utilisateur de DCCpp que j’utilise simultanément à une centrale Lenz pour la commande des locomotives, je voudrais aller un pas plus loin. Est-il possible d’interfacer une appli comme Z21 avec DCCpp ? Je précise que j’utilise DCCpp en liaison internet avec JMRI.
Merci de vos conseils -
Bibliothèque DCCpp 4 mars 2023 09:36, par Jean Jacques
Je souhaite monter une petite station et j’apprécie les fonctionnalités de cette bibliothèque.
J’ai deux question :
est-il possible de ne pas afficher les ligne ci-dessous dans le moniteur série, pour mes extension j’utilise des PCF8574 et PCF8575 et avec le flux d’information c’est plus compliqué pour faire la mise au point.J’ai tenté des de dévalider des lignes dans DCCpp.h mais sans succès.
T1 3 0 0
T1 3 44 0
T1 3 56 0Ma deuxième question peut-on utiliser cette bibliothèque avec Rocrail.
Par avance merci pour les raiponces.
Cordialement.-
Bibliothèque DCCpp 12 mars 2023 09:19, par Jean Jacques
Pour l’affichage des données dans le moniteur série je n’avais pas commenté la bonne ligne donc ce problème là est résolu.
cordialement.
