jeudi 25 avril 2024
Visiteurs connectés : 62
. Par : bobyAndCo
Un contrôleur USB/série, Ethernet et WiFi pour DCC++ Dans un premier temps, nous allons voir comment piloter notre Arduino directement relié au port USB/Série de notre ordinateur. C’est la première des possibilités offertes par DCC++ sur un UNO ou sur un MEGA. Elle correspond au réglage COMM_INTERFACE 0 du fichier config.h de DCC++ (...)
Piloter son Arduino avec son navigateur web et Node.js (4) 28 décembre 2018 01:01, par bobyAndCo
Hello Kobal,
Thank you for your appreciations. If I understand correctly, you would like to add extensions to be able to control outputs of the Arduino MEGA to turn on or off DELs for example.
This would require not only adding these functions to the HTML page, but also modifying DCC ++ BaseStation. I already had the opportunity to say before I did not advise to modify DCC ++ BaseStation by adding this type of functionality.
The work that we realized on the Satellites shows that this type of functions can be realized by specific interfaces like what I present in this video for example :
https://youtu.be/ZPbDnoiOLdE
Or this one :
https://youtu.be/0wTkDJWdN_c
When you talk about current sensors, I think it’s something similar to what we do with Satellites, and it shows the areas occupied by locomotives in red on the graph.
We are going to publish a series of articles on this subject, but it takes time and we do not have many of them.
Do not hesitate to return regularly on the homepage of the site. Do not hesitate to come back to me if I did not understand your request or that I do not answer well.
Best regards.
29 Messages
Rubrique Programmation
