samedi 27 avril 2024
Visiteurs connectés : 37
. Par : bobyAndCo
float current;
float voltage;
float vp = 0.022;
long tempo = 1000;
long currentTime;
float vMax = 12.0; // Volts
float iMax = 1.0;  // Amp
  pinMode(2, OUTPUT);
  digitalWrite(2, LOW);
  currentTime = millis();
  voltage = analogRead(A0) * vp;
  current = 0;
  for (int i = 0; i < 100; i++) {
    current += analogRead(A1);
  current /= 15000;
  if ((voltage > vMax) || (current > iMax)) {
    Serial.print(" stop\n");
    digitalWrite(2, HIGH);
    delay(1000);
  if (millis() > currentTime + tempo) {
    Serial.print("Voltage : \t");
    Serial.print(voltage);
    Serial.print(" v\t\t");
    Serial.print("Courant : \t");
    Serial.print(current);
    Serial.print(" mA\n");
256 Messages
